AlfaPete
Nye spesialproduserte produkter fra Jason hos Alfissimo på G for AR 164
I am working on some new items coming soon.
New Billet ABA Serpentine Tensioner Pulleys -12V
Pulley is manufactured from 6061-T651 aluminum and comes with a 20k RPM SKF bearing. Larger 6203 bearing and will all come with krytox grease standard. Super lightweight to reduce rotating mass. I may even make them a few mm larger to reduce speed but not by much as it will be difficult to fit OEM belt if I go too big.
New Billet ABA Serpentine Belt Tensioner Pulleys-24V
This pulley is manufactured from 6061-T651 aluminum and comes with a 20k RPM SKF bearing. Larger 6203 bearing and will all come with krytox grease standard. Super lightweight to reduce rotating mass.
Great thing about both is that they will have a cir clip installed on them to keep the bearing in but for easy uninstall if you ever need a new bearing, not that I see that happening but it is there.
I do not have specific's on pricing but they will be less or equal to OEM.
I am going to try my best, really try my best to reproduce the 24V factory tools. This one may take some time.
Anyways, just some new things I am working on.
Thanks
Jason
kilde:
http://www.alfabb.com/bb/forums/164-168-1991-1995/160965-alfissimo-new-items-coming.html
More info:
All the work is done in a Aerospace shop, 70% of work is for Delta
Air Lines tech ops, they build many airframe and engine parts which we
either get full PMA certification on, or sell them as owner operator
produced parts. The quality is very good (it has to be for FAA and Delta)
and they are using state of the art HAAS CNC mills circa 2008, nearly a brand
new shop. Their native CAD platform is Catia V5 and Solidworks but they can
pull in any standard CAD file.
I will be producing all the 24V special tools but they will be later this summer. I am pushing the pulleys first.
Jason
