Gjest ideal
Mito med multiair motor lansert.
Dette er spanande saker du.Mito med dei nye multiair motorene er nå lansert og det er gode tall.120hk får nå 135hk,mens den før hadde utslepp på 145g/km har den nå 129g/km.
Same ser ein på 155hk som i multiairutgave får 170hk.Her er utsleppene redusert frå 153g/km til 139g/km på den nye.170hk på 1,4l det gje 124hk/l.Det er rekord for Alfa(iallefall til GTAen kjem,om nokon gong)og gjer att den når 100 på rett over 7sek.Toppfart er 219km/t mens momentet i sport er 250nm.Denne går nok godt!!!!! :)
"The innovative Multiair system controls the air in controlled-ignition petrol engines without the usual throttle valve, and therefore with a greater degree of flexibility than mechanical timing systems. This electrohydraulic valve activation technology is based on the insertion, between the camshaft and the engine inlet valve, of an amount of oil (high pressure chamber) that can be varied by a valve, which in turn is controlled by a specific electronic control unit."
"This allows the opening profile of the valve to be modified in response to the request for air from the engine and to the running speed. Different strategies can be employed (Early Inlet Valve Closing – EIVC, Late Inlet Valve Opening – LIVO, or Multi-Lift) to optimise combustion efficiency, with considerable benefits in terms of power output, torque, consumption and emissions. Another advantage of this system is the fact that the air pressure upstream of the valves is always constant. This characteristic allows the torque response of the engine to be increased without any delay, on both an aspirated and a turbocharged engine, increasing the ‘fun to drive’ factor."
